Bolt-on Front Receiver
Old Nov 4, 2005 | 12:39 PM
Mudinyeri's Avatar
Mudinyeri
Default Bolt-on Front Receiver
Has anyone added a bolt-on front receiver to their 3rd Gen 2500? I'm thinking of adding one so I can use my mobile winch on my truck as well as my Jeep, but would like to see one installed before I shell out the money for the receiver. I'm guessing there's a bit of plastic cutting that's necessary. Pics would be appreciated.
Old Nov 4, 2005 | 05:07 PM
dpfolie's Avatar
dpfolie
Default RE: Bolt-on Front Receiver
I put one on. It is a Hidden Hitch. It mounts to your bumper bolts and to the frame. You have to drill two holes in your frame which I found to be a lot easier than I thought using a hole bit. You do not need to cut any plastic.
http://www.etrailer.com/products.asp...500+Series&ob=
[IMG]local://upfiles/18964/2B9E7E91F9ED4AA28759F6B8D8D77EBD.jpg[/IMG]
[IMG]local://upfiles/18964/380FCCC97F8F4A7BB4139B3B88A252C3.jpg[/IMG]
Old Nov 4, 2005 | 06:18 PM
Mudinyeri's Avatar
Mudinyeri
Thanks for the pics. That looks like it hangs pretty low. Have you ever hung it up on anything?
Old Nov 4, 2005 | 09:21 PM
HemiBuell's Avatar
HemiBuell
I saw one in the JC Whitney catalog, I think it came through the bumper insert, not below it.
Old Nov 4, 2005 | 10:39 PM
frogslinger's Avatar
frogslinger
couple people make them You either have to cut a hole through the insert or remove it complelty... I think if I do one i will cut the whole and put a receiver mounted license plate holder in the front receiver so it is concealed when not in use.
