03 Ram Starting Issues
Old Oct 22, 2015 | 11:20 AM
Seatacslim's Avatar
Seatacslim
Default 03 Ram Starting Issues
I have a 2003 Dodge Ram 1500 SLT, Was running great after 2 long road trips then parked. 30 minutes later went to leave for dinner and would not start just turned over. 2 days later I realized that I could turn over for 3 seconds and it would start every time. I changed out the fuel pump. Problem fixed. Fired right up at least 10 times. After sitting for a few day I went to start it and it did the same thing that I mentioned above. Then it fired right up, parked it in front of the house running. After 5 minutes I went outside and it was dead and took the 3 seconds to fire up again. Any suggestions?
Old Oct 23, 2015 | 01:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Hard to guess on this one. When was the last time you did a full tune up? Coils, plugs, wire, ect?
Old Oct 30, 2015 | 11:42 AM
RacerHog's Avatar
RacerHog
Change the Fuel Filter.....
Old Oct 30, 2015 | 05:30 PM
p38251's Avatar
p38251
No fuel filter. Its a sock on the end of the fuel pump.
Old Oct 31, 2015 | 12:36 PM
abarmby's Avatar
abarmby
Any codes?
With 03 you can do the key dance.
Al.
