Headlight issues
Old Oct 25, 2015 | 05:01 PM
Jacob007's Avatar
Jacob007
Default Headlight issues
Hello all I'm new to this forum.
I recently bought aftermarket headlights, once I installed them and started adjusting the beams I maxed out before the beams reached the spot I was aiming for on the garage. Anyone have any tips or run into similar issues? Thanks.
Jacob.
Old Oct 25, 2015 | 07:39 PM
p38251's Avatar
p38251
What are you working on.
Old Oct 25, 2015 | 08:32 PM
Jacob007's Avatar
Jacob007
2", 3" dropped and leveled 2004 Dodge Ram 1500 5.7l. You know how on these models you have 2 adjustment points, horizontal and vertical right? I've got the horizontal where it needs to be, but on the vertical adjustment I've maxed out the screw before it get to the point on the wall. I'm curious if anyone else has ran into this issue and possibly some pointers or tips.
Old Oct 25, 2015 | 09:04 PM
p38251's Avatar
p38251
Is the spot your adjusting to within the normal range of headlight adjustment. The headlights you chose because the truck is lowered may not be able to attain that adjustment. The light manufacturer may be able to help.
