Rack and pinion failure.
Old Oct 26, 2015 | 08:59 AM
philipjames5k5's Avatar
philipjames5k5
Default Rack and pinion failure.
I have an 2002 ram 1500 with 20" xds with 305s and 3 inch front lift, and 2 inch rear lift. The rack and pinion blew all of its seals out of the driver side and leaked all the power steerin fluid out of the boot. I am pretty sure it failed because of the height adjustment. Is there something I can do or add to keep the hight of my truck without having to worry about blowing the seals again?
Old Oct 26, 2015 | 06:39 PM
philipjames5k5
Any opinions would be greatly appreciated
Old Oct 26, 2015 | 07:34 PM
HammerZ71's Avatar
HammerZ71
Lift, larger tires, heavy 20" wheels all work to wear down front end components faster. That said, I had 35" tires on 4" of lift for almost 10 years on my '04, IFS 1500 and although I had to replace tie rod ends, upper and lower ball joints, wheel bearings and CV axles, I never had a hint of a leak out of the rack.
Your rack is going on 14 years old. Replace it, odds are you'll never have a problem again...
