Dead Lifter...What Brand is a good brand to replace lifters with?
Old Nov 16, 2015 | 06:46 PM
JoshSlash87's Avatar
JoshSlash87
Default Dead Lifter...What Brand is a good brand to replace lifters with?
After further investigation on my 04 Hemi Ram, I believe I do indeed have a collapsed exhaust lifter on cylinder #2, I can't shore up the play in the rocker by neither re-torqueing, or replacing pushrods or rocker shaft assembly so the play must be in the lifter.
I've come to grips that I've got to pull the heads & replace the lifters, what brand of lifters are proven to be good in these engines? I don't want to be replacing them again.
Also what brand of 6.1 Exhaust valve springs & push rods would you guys recommend?
I figure if I'm replacing the lifters, I mine as well replace the valve springs as well.
Old Nov 17, 2015 | 11:19 AM
HemiLonestar's Avatar
HemiLonestar
OEM all around.
