Ram1500 trannsmission issue
Old Nov 23, 2015 | 02:33 PM
Steven Steele's Avatar
Steven Steele
Default Ram1500 trannsmission issue
I recently had a strut anchor fall off the band and on top of the valve body blocking the linkage from going into reverse or park. I removed the pan and valve body replaced the anchor and adjusted the front and rear bands to spec. reinstalled the valve body a new filter, pan gasket and filled with at4. when I started the truck I got engine codes p1763, p0753, p0713 and the transmission was in limp mode. Is there a way to reset these and get the tranny out of limp mode? I tried the remove the battery cables ect they were removed but came back immediately. Any ideas?
Old Nov 24, 2015 | 12:02 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You still have damage in the trans or a problem somewhere if it is still in limp mode. While disconnecting the batt will wipe the codes, they will come back if the issue is still there
Old Nov 24, 2015 | 02:52 AM
Black02CrCb's Avatar
Black02CrCb
sounds like you have damage to the wiring harness. each and every code has a similar problem that equates to a cut or damaged wiring harness/control harness
