LED Plasmaglow Igniters.
Anyone have these or can give an informed opinion?
Do they need the "cancellor" kits to get them to work with our CAN bus system?
http://www.plasmaglow.com/pro-series...onversion-kit/
Al
Al
Idk bud. Look like every other led headlight made that I've seen. They either come with cooling fans or aluminum heatsinks and personally, I still think HIDs with projectors that have cutoff shields is the best way to go .
Your probably right Weed.
Heres a reply I got today from Plasmaglow themselves.
We now have two versions of our LED Conversion kits.. we have our standard version, and a new "pro" version. Both kits will work on your vehicle, however I would recommend the pro version for a couple reasons. The fan is smaller, elimination any possible sizing problems. It will fit in any headlight housing. The second reason is that a Canbus Canceller will not be required. The standard versions have a slightly bigger fan and although a canbus canceller is not always needed, it will be more likely with this kit.
Both kits are very bright, while not blinding oncoming drivers. And yes, they will plug right in to your stock headlight housing!
For a 2003 Dodge Ram 1500 it looks like you will need the 9007 kit. This will be both your low and high beams. We are currently out of stock on the standard version, but have the pro version in stock.
Here are the links to our igniters:
Standard Kit: http://www.plasmaglow.com/led-ignite...onversion-kit/
Pro Series: http://www.plasmaglow.com/pro-series...onversion-kit/
