2004 2500 Front End "clunk"
Old Dec 22, 2015 | 09:49 PM
Hemi20's Avatar
Hemi20
Default 2004 2500 Front End "clunk"
First time posting on this thread so I will be as descriptive as possible,
I own a 2004 Dodge 2500 quad cab with the 5.7, I noticed a "knocking" noise last week, it is located (or seems to be) on the drivers side front end, at first it was only during deceleration under 5 MPH and slowed with wheel speed, and is not effected by breaking, at first it was effected by turning, now it is not, and it has become more pronounced and starts at about 15 MPH, and decreases with wheel speed, does not make noise during acceleration. I had the front end serviced just before the issue started, they said my wheel bearings are fine and my bushings looked fine, then my problem started. any suggestions would be a huge help, Also, only seems to happen after 10 or so minutes of driving, and does not happen in 4x4
Old Dec 23, 2015 | 02:57 PM
mitch611's Avatar
mitch611
Really sounds like CV joint or axle. I noticed the noise wasn't as pronounced during acceleration and non-existent in 4x4, however mine is a 1500.
Old Dec 23, 2015 | 03:25 PM
Hemi20's Avatar
Hemi20
yea what you said are my exact symptoms, I played with the u-joints and they did not seem like the issue, but im not going to start tearing it apart a week before snow flies, ill take it to the shop tomorrow. ill post after what the issue was
Old Dec 23, 2015 | 07:51 PM
p38251's Avatar
p38251
Wheel bearings and u joints can be tight, and still be bad. How many miles on the rig?
Old Dec 24, 2015 | 06:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just take it to a shop that does front end alignments and let them tell you what parts it is. Replace them yourself and let them do the alignment
Old Dec 26, 2015 | 04:11 AM
rought's Avatar
rought
My 04 did exactly that I replaced everything on the front end.. It ended up being the lower control arm bushings. They are a bitch to change though,, I would recommend getting the whole lower control arm with bushing already installed…
http://www.oreillyauto.com/site/c/de...%26+components
Old Dec 27, 2015 | 10:02 AM
Gone Fishin's Avatar
Gone Fishin
check the u-joints on the front drive shafts, most likely find the needle bearings are gone. These are very easy to check----2500's don't have cv shafts sfd. Chances are, if it is these, you'll be going through the whole front end anyway.
