Wheel bearing issue maybe??
Old Jan 11, 2016 | 06:22 AM
englishdodge's Avatar
englishdodge
Default Wheel bearing issue maybe??
Hi guys , i hope i`m in the right place for this thread !
I have an 04 1500 quad cab , it`s done 136000 , Ive done all the work i need to do myself , mostly replacing brakes , bearings on the front , ball joints and u joints. Oil and filter change every 3 - 4000 miles. Its a 2 wheel drive version and has developed a funny whirring / rubbing sound which really comes into play around 35 mph. Could be a bearing or something in the rear i thought.
I jacked up the back , put in axle stands , chocks at the front and put it gear to see what i could hear. However the passenger side rear wheel did not want to move until speedo was around 50 or so. This wheel was very stiff to move which is why i am thinking its the bearing. Or am i missing something , Is it something to do with a slip diff? The drivers wheel moves quite freely.
I guess this is a process of elimination but i wondered if anyone else had been through this.
Many thanks for any advice..
Old Jan 11, 2016 | 09:49 AM
p38251's Avatar
p38251
Does the noise change if you turn? How long ago did you do the front bearings? Good quality part?
Old Jan 11, 2016 | 10:19 AM
englishdodge
Hi , thanks for reply , I did the passenger front a few years back , the drivers front is good , no the noise is not there when you turn , Its hard to tell if its front or back , you can only hear it from inside at that speed of 35 ,
I dont know , i think i`ll have to take it apart and see whats what.
I`ve not really done anything on the rear of the truck.
Parts are from a good quality place here in the UK .
When that front bearing went it made a hell of a noise and was easy to identify
Thanks again.
Old Jan 11, 2016 | 01:40 PM
p38251's Avatar
p38251
I would replace the drivers side. It is possible for bearings to be bad, and not show any sign.
Old Jan 12, 2016 | 03:40 AM
JoshSlash87's Avatar
JoshSlash87
Make sure you go with ONLY a Timken bearing, the standard Duralast wheel bearings at Auto Zone & standard O'Reilly wheel bearings are a flat bearing style and not tapered like the Timken is, the Timken can withstand side loading during turns as well as normal loading. The standard $120 bearings at Auto Zone you'll be replacing in a year no matter how much you drive your truck, do yourself a favor and get the Timken one for $104! cheaper and beefier!.
Old Feb 6, 2016 | 09:43 PM
rex941's Avatar
rex941
My truck had the same symptoms and it turned out to be the driver side front wheel bearing. I changed both front bearings for good measure and I like the Timken bearings as well. If you have access to the internet there plenty of good sources for those parts. I like rockauto. Have fun!!!
Old Feb 7, 2016 | 01:34 PM
englishdodge
Very kind of you guys to reply , yes the front bearings was the next port of call , i have never done the drivers side before . I`ve just serviced the rear brakes which have not been touched since it left the production line. I am in England but will try and source those Timken bearings. We have good suppliers in the UK now so should not be a problem.
Cheers.
