Wiper problems
Old Jan 13, 2016 | 10:50 AM
Nsmitty21's Avatar
Nsmitty21
Default Wiper problems
I have been having an issue with my wipers the last few days. Basically some times they work, sometimes they dont move at all, and sometimes they will stop in the middle of my windshield. The odd part is when they stop they act like they are under extremem load and slow down until they stop. Then I can get them going again like normal if I get out and "help" them a bit. After searching I didnt find anything quite like this. Could it just be my motor going bad? The truck only has 60K miles on it.
Old Jan 13, 2016 | 06:02 PM
p38251's Avatar
p38251
Very possible. Wiper motors work hard. Check voltages at the motor, make sure they don't drop. That could be a sign of the relay going.
Old Jan 14, 2016 | 01:47 AM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
Interesting symptoms. My wipers kind of have a mind of their own, but always have for as long as I can remember (bought the truck new in 2005). If I turn on the delay, sometimes they work as they are supposed to, sometimes they won't work until I switch them to "low", sometimes they continue swiping for 5-10 cycles, and other times they will stop in the middle if I move the switch. I'm sure they worked correctly when new, but I can't remember a time when they were not unpredictable on delay.
Hope yours are an easy fix.
Old Jan 14, 2016 | 11:25 AM
Nsmitty21's Avatar
Nsmitty21
Wiper relay would make a bit of sense. But where are the relays on this? I didn't see anyting wiper related in the box under the hood.
Old May 4, 2016 | 11:41 AM
SkeeterMark's Avatar
SkeeterMark
Can anyone help out on the location of the wiper relay(s). My wipers were going extremely s l o w, then intermittent, and now they don't move at all. They will just twitch slightly when the switch is turned on.
I have replaced the wiper motor and the turn signal/wiper switch and it behaves identically to before. I have read there are two wiper relays...somewhere.
The fuse box under the hood does not have relays in it, soooo.....
Anyone know where they are? or is there something else I should be looking at for a cure?
Thank you in advance for any help.
Vehicle is 2007 3500
Old May 6, 2016 | 01:30 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb Wiper Relay Location
Both relays are in the PDC/IPM (Fuse box next to the battery).
One for ON/OFF the other for HIGH/LOW.
