Lower Idler Pulley Bolt Size - Truck DOA right now!
Old Feb 20, 2016 | 08:38 PM
zman9119's Avatar
zman9119
Exclamation Lower Idler Pulley Bolt Size - Truck DOA right now!
Does anyone know the size of this bolt, length, pitch?
For a 2003 2500 5.7l, lower idler pulley.
Had been having a weird noise every once in a while and finally got around to replacing the pulleys today only to find the lower idler pulley impaled into the water pump housing. Enough to say the bolt was snapped off and I cannot find post or size or manual that has the correct information for this along with now having to do the water pump unit too due to the mount snapping.
The parts books and manuals all vary on what is correct so I am looking for help on this one.
Thank you a ton in advance for the help
z
Old Feb 21, 2016 | 07:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
https://dodgeforum.com/forum/3rd-gen...-cam-swap.html
looks like the bolts in both upper answer lower are the same size.
see step 27 in the link above
