Heater mode selection issue...
Old Feb 22, 2016 | 02:47 PM
JoshSlash87's Avatar
JoshSlash87
Default Heater mode selection issue...
When I select the floor heat only option it still has the windshield on.
Now every other mode works as intended and it works pretty speedy as you'd hope it to, I'm wondering if this is in the switch or the dreaded blend door issue. I tend not to think its the blend door because if I choose just dash vents that face me it shuts off the windshield and shuts off the floor just fine and when I select the bi level feature it goes to floor and dash just like its supposed to. Also when I want just windshield heat it also selects that just fine, so each side of the spectrum works except floor heat only.
It doesn't appear to be a blend door issue because they all work. Maybe somebody can clear up why or why not this may be. Thanks much potential repliers!
Old Feb 26, 2016 | 05:02 PM
JoshSlash87
nobody?
Old Feb 27, 2016 | 12:13 AM
66three83's Avatar
66three83
It's defiantly a door issue. If you stick a long screwdriver in the vent on the drivers Side floor vent, you can manually open it for floor heat. Go to heatertreater.com for more detailed info.
Old Feb 29, 2016 | 08:36 AM
JoshSlash87
Floor heat works, it just doesn't shut off the windshield when I select floor only and my face burns off when I only want to warm my feet up. All the controls work normal, except when I select only floor heat it keeps the same settings as windshield/floor mix. All other positions work as they're supposed to which is why I'm suspecting it might be a switch issue and not a door issue.
