Bilstien Shock question
Old Mar 1, 2016 | 05:53 PM
Jared Sweigart's Avatar
Jared Sweigart
Default Bilstien Shock question
I'm looking at getting a new set of shocks for my 06 ram 2500. It currently has the revtek ones on that came with the 4.5 inch lift I put on. I was looking at getting a set of bilstiens, but I cant find anywhere if the 5100 series will be long enough for travel in articulation. Does anyone run 5100s or the 5125?
Old Mar 1, 2016 | 06:01 PM
p38251's Avatar
p38251
There are websites that will list them by part number and application. IE mine are 0-2.5 inches of lift. Try suspension connection. Or SD Springs
Old Mar 1, 2016 | 06:14 PM
Jared Sweigart
alright, thank you
Old Mar 1, 2016 | 08:11 PM
KasperR34's Avatar
KasperR34
I run 8 bilstein 5100s on my 1500, all designed for a 2500 with 0-3" of lift, I matched them all by extended and collapsed lengths. They are listed for inches of lift as well.
Old Mar 1, 2016 | 08:15 PM
Jared Sweigart
also, for the rears. Since the lift came with 4.5 up front and a 2 inch block in the back, id assume id only need shock for a max of 2" lift correct? Or would I have to make up for the factory rake it used to have on top of the 2 inch
Old Mar 1, 2016 | 08:55 PM
p38251's Avatar
p38251
Shocks will not lift the truck. You can run the same length all around.
