Abs light and parking light in after changing axle shaft u-joints
Old Mar 27, 2016 | 09:55 AM
ccrites56@yahoo.com's Avatar
ccrites56@yahoo.com
Default Abs light and parking light in after changing axle shaft u-joints
Changed the front u-joint the other day and the rear drive shaft joints after I got everything put back together and light and parking break light came on as soon as I started the truck...2006 Dodge r 3500 quad with 5.9
Old Mar 27, 2016 | 10:00 AM
Check all the wiring.
Old Mar 27, 2016 | 10:03 AM
ccrites56@yahoo.com
Wiring looks good could I have damaged the sensors ...had to beat hub out with 3 lb hammer
Old Mar 27, 2016 | 03:53 PM
p38251's Avatar
p38251
You had to beat the hub off the bearing? If you didn't replace the bearings I would start there.
