3.7 engine problems
Old Mar 30, 2016 | 08:06 PM
taswell's Avatar
taswell
Default 3.7 engine problems
Hi
I just bought a 2002 Ram regular cab short bed 2wd. The truck is nice but the engine is messed up pretty bad. It has metal clanging in the front of the motor like a bolt flopping around in the timing chain area.
I have read that this engine can have some major issues and was wondering if it might be worth a swap for a different engine that's less prone to damages?
Like I said, the truck is nice and I got it cheap ($500)
Any ideas? No used 3.7 motors close and rebuilt ones are $2700 and up.
Thanks for any help
Old Mar 30, 2016 | 10:42 PM
p38251's Avatar
p38251
Look it over, see if you can find something obvious. How's oil pressure? Does it run hot?
Check the fan area. Loose hardware.
Old Mar 31, 2016 | 03:38 PM
taswell's Avatar
taswell
Oil pressure is fine. I took the belt off to eliminate any of the accessories. The noise sounds like it's around the timing chains area. I dont want to run it very long for fear of breaking more.
Old Apr 2, 2016 | 09:21 PM
HammerZ71's Avatar
HammerZ71
Crack it open and find out. Could be as simple as a tensioner broke. Pretty common with higher mileage Chrysler OHC engines.
The 3.7 and 4.7 are actually pretty stout - UNLESS THEY OVERHEAT, doesn't take much of an overheat to toast one...
Old Apr 3, 2016 | 11:48 AM
taswell's Avatar
taswell
I was getting ready to pull the motor and a guy came and offered me $1200 so I sold it.
Im not much of a mechanic on trucks with an ecm, but I'm pretty good with the mechanical aspects.
Thanks for the timely replys guys.
