Help with Brake question
Old Apr 13, 2016 | 05:22 PM
1forrest1's Avatar
1forrest1
Default 2 week old rotor turning purple, help?
So I just installed new pads and rotors 2 weeks ago. I noticed my passenger side rear is turning purple on the outside of the rotor only on the side where it mounts to the hub. What can be causing this? The inside is perfectly fine so I don't think the caliber is getting hung up.
Old Apr 13, 2016 | 09:02 PM
p38251's Avatar
p38251
How hot I. The rotor after you drive it?
Old Apr 14, 2016 | 04:26 PM
bleachcola's Avatar
bleachcola
did u clean the new rotors really well with brake cleaner after install on both sides?
Old Apr 14, 2016 | 05:22 PM
1forrest1's Avatar
1forrest1
idk how hot the rotor is temp wise, I don't have a laser thermometer. But if you even touch it for a split second, you burn your skin. and yes I used half a can of brake cleaner when cleaning off the rotors before install.
Old Apr 14, 2016 | 09:15 PM
p38251's Avatar
p38251
Ok. If you burn your skin. Something is dragging. Rotor show be warm, not hot. Did you lube the caliper sliders? Is the e brake dragging.
Old Apr 15, 2016 | 10:24 AM
TejasMtnBiker's Avatar
TejasMtnBiker
caliper slides catching do they have any rough spots? if so just replace them with new ones getting that hot will warp soon too
