06 ram 4.7 misfires/ HELP
Old May 12, 2016 | 01:50 PM
p38251's Avatar
p38251
May want to find someone with a factory scan tool. There are a bunch of tests that can be done. Prior to throwing parts at it.
Old May 12, 2016 | 09:04 PM
Friar Tuck's Avatar
Friar Tuck
Might check the plug and wiring for that o2 sensor, since it's been replaced. Maybe shorted/melted/frayed somewhere?
Old May 12, 2016 | 11:19 PM
cmunk32's Avatar
cmunk32
Again I have changed the fuel pump but would anyone here think maybe I have a faulty pump? I could see the pressure regulator being bad but would that cause misfires but than correct itself at high speeds than run fine? I run sea foam through the tank every few months and throw some premium in the tank so discount bad gas issues. And wouldn't stuck fuel injectors have different symptoms as someone else suggested.
Old May 13, 2016 | 02:12 AM
Friar Tuck's Avatar
Friar Tuck
I am not that familiar with fuel pump/regulator operation. I don't know if they are combined in a single unit, or separate. Does that high pressure hold, or does it bleed off? I understand there's a check valve in the pump module. Maybe it is faulty. I've also seen where some brands of pumps don't work well in our trucks. Hope someone with more knowledge can help you.
Old May 13, 2016 | 02:19 AM
Friar Tuck's Avatar
Friar Tuck
Lightbulb O2 Sensor errors
Just for troubleshooting purposes, would it be a lot of trouble to swap the upstream sensors from one side to the other and clear the codes and see if you still get the code? If it doesn't move with the sensor, there's probably a wiring problem.
Old May 13, 2016 | 08:44 AM
cmunk32's Avatar
cmunk32
I looked as far as i could, they go ito the main harness pretty quick so i cant see very far.
Old May 17, 2016 | 05:58 PM
Friar Tuck's Avatar
Friar Tuck
Any good news?
Old May 18, 2016 | 08:26 AM
cmunk32's Avatar
cmunk32
Any good news?
Nothing yet, i have a mechanic friends whos gonna check the power goin to the fuel pump this weekend hes comvinced its the pump, im convinced ecu, which i found them pretty inexpensive on the web, so this weekend fuel system again next week electrical again lol. Ill keep it updated if i find any issues
Old May 18, 2016 | 02:36 PM
gcburkett's Avatar
gcburkett
If you can capture o2 and trim data. Have you check for exhaust leaks.
Old May 19, 2016 | 08:02 AM
cmunk32's Avatar
cmunk32
No exhausts leaks everything looks as it should, the upstream #1 o2 sensor is really bothering me with the heater line closed loop failure... But in my mind that problem would eminate from the ecu or tipm, now i already changed the tipm so im leaning toward ecu, but im gonna have him test the fuel pump voltage an see where that goes
