2005 ram tranny noise
Old May 25, 2016 | 05:29 PM
Mrbill1's Avatar
Mrbill1
Default 2005 ram tranny noise
I have a 2005 Dodge Ram pick up with 5.7 engine and auto trans. I have a tapping sound coming out of the trans. It gets really loud right before it down shifts. From a stop it is slight.
Old May 25, 2016 | 05:33 PM
How many miles? Hows the fluid level and condition? Transmission ever been serviced?
Old May 25, 2016 | 06:20 PM
Mrbill1's Avatar
Mrbill1
220,000 miles fluid is full and is not burnt never been serviced
Old May 25, 2016 | 09:08 PM
If it's something internal it may be time for a service. Really can't tell you definitively over the Internet.
Old May 25, 2016 | 09:43 PM
p38251's Avatar
p38251
Possible Cracked flex plate. Or broken torque converter neck
Old May 25, 2016 | 10:08 PM
Either way, best to get it properly diagnosed asap before more damage is done.
Old May 26, 2016 | 06:39 AM
JoshSlash87's Avatar
JoshSlash87
I'd make sure a u-joint isn't ready to go. Get under the truck (use proper safety precautions) grab the drive shaft & check for play. Also inspect the differential yoke.
my 97 Ram would make that noise when the transfer case chain had slop in it. Noise went away with new transfer case.
