Is my compressor shot so I can order one
Old Jul 18, 2016 | 07:41 PM
Kevno6's Avatar
Kevno6
Default Is my compressor shot so I can order one
Compressor kicks on but blowing hot air, Condenser fan working all fuses good also relays. I had service done on it today, vacuumed and recharged and no leaks. After recharge the compressor would not kick on, check the volts at plug and they are good. Was going to order new compressor but on the way home today it kicked on and had great ac. I decided to turn it off and back on again and compressor wouldn't come back on. Is this a sign that clutch is bad maybe not catching. Just want to know before I drop money on compressor. Thank You
Old Jul 18, 2016 | 09:33 PM
p38251's Avatar
p38251
Did they check the pressure switches?
Old Jul 18, 2016 | 09:38 PM
Kevno6's Avatar
Kevno6
Not that I know of. Where would those be located
Old Jul 18, 2016 | 09:58 PM
Kevno6's Avatar
Kevno6
I see on rock auto they have pressure switch's for hi and low. And a clutch cycling switch which says its accumulator mounted.
Old Jul 18, 2016 | 10:19 PM
Kevno6's Avatar
Kevno6
I just looked and have no switch on accumulater and no pressure switches on hi or low pressure lines
Old Jul 18, 2016 | 10:38 PM
Kevno6's Avatar
Kevno6
Ac runs on a evaporator temp sensor which when bad causes system to freeze up most of the time. No pressure switches.
Old Jul 19, 2016 | 08:48 AM
Kevno6's Avatar
Kevno6
Scanned vehicle this morning and got code p1598 ac pressure sensor curcuit hi voltage. Any idea where to look. I can't locate any pressure sensors. Only evaporator temp sensor under dash.
Old Jul 19, 2016 | 10:56 AM
p38251's Avatar
p38251
Back of the compressor? Has to have hi and low switches. Never seen one that doesn't. Look for an electrical connector in the lines. Usually 2 wires.
Old Jul 19, 2016 | 04:38 PM
Kevno6's Avatar
Kevno6
Found one on top of compressor and changed it. Compressor kicked on and drove for 20 minutes with ac then didn't come back on after I shut off truck and restarted
Old Jul 19, 2016 | 07:07 PM
Kevno6's Avatar
Kevno6
Hour after I got home I went out full air conditioner. Sat and watched kids for 45 min at Tae Kwon Do and no ac when I came out. What else can I look at other that compressor or should I face the fact that it's going. Just doesn't seem like thats the problem.
