Stalls out
4.7 . 230,000.
Cam shaft sensor
Crank sensor
Throttle body, there were 2
Fuel pump- filter
Last time before it completely died I could drive it it would stall out no power to anything , wait a bout 10 min then i could start it again ,just to stall out a couple miles down the road . The more gas I would give it the sooner it would stall . Now after starter fluid start it runs good till I put it in gear and push the gas then it stalls out
Cam shaft sensor
Crank sensor
Fuel pump- filter
Have pressure, changed plugs,haven't checked compression, I checked grounds, the best I know how , I'm a YouTube mechanic
Having fuel pressure, and having the correct pressure two different things. Need a fuel pressure gauge. I am sure someone on here has the specs. You can also check weeds page. He has downloadable shop manuals that can he you out as well.
