3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hi all, can someone please help. my 4.7 1500 Ram has started to overheat when I drive over 2000 RPM, the temp goes up above the halfway mark when I work the motor, almost into the red, if I ease off it will drop down to halfway. The temp did stay at halfway no matter how hard I hit the gas, up until recently, what could it be?
He's teasing you. Need to find out why it's running high. Any coolant leaks? Keep the overflow reservoir filled to the line on it. Don't use tap water. Use distilled water and antifreeze mixed 50/50. When it's cooled, take the radiator cap off and check to see if the radiator is full. Get a new radiator cap. How does the coolant look? How long has it been since it was flushed and replaced?
