2005 Ram 1500 check gauges/oil pressure
Every morning when I start the truck the oil pressure gauge never goes up and my check gauges light comes on. So I have to start it a second time before it reads. This gets very annoying having to start my truck two times in a row. It seems to do it more often when it is cold outside.
Thanks |
Originally Posted by John Quinones
(Post 3313102)
Thanks |
Oil pressure sending unit on the way out?
Originally Posted by Chet Ubetcha
(Post 3313188)
Do your front timing cover and water pump gaskets seal properly? Mine had a slight leak above the sender and caused it to not work. Changing the sender worked for a while until the new one got wet
Replace sender, test pressure with pressure gauge after removing sender. Run a round of motor flush to clean up oil passages. I did all these things when I heard the "ding".
