Where the squeaks coming from??
So I have a 2004 1500 5.7L 4x4 Laramie Quadcab. 130k
When I get in the cab or jump up into the bed it squeaks everywhere.
Also running over rougher roads. What am I looking at greasing or replacing. I can't pin point where the squeaks are coming from.
thanks
B
thanks
B
Might want to have a friend get in the truck while your under the truck listening to where the noise is coming from.
could be leaf spring bushings
could be shocks are loose
could be cab mounts to the frame
check for loose spare tire
check for loose gas tank straps.
I have a similar problem where mine makes a creaking noise on bumpy roads. I had someone jump on rear bumper but will not make noise so I just oiled the 4 ends of my leaf springs. Hoping it will do the job. Haven't had time to drive truck but hope that was my problem.
Good luck on yours
Good luck on yours
