Does the Superchips 3845 have an option for Fog lights and Hi beams?
Old Nov 11, 2016 | 02:26 PM
lharrell79's Avatar
lharrell79
Default Does the Superchips 3845 have an option for Fog lights and high beams?
I have a 2008 4.7 1500, and would like to have the fog lights and high beams on at the same time. I'm aware of the brite box, but if the superchips can do it, I would rather go with the superchips. The following is taken from the powerpaq manual:
Daytime Running Lights (Run Lights) - allows you to adjust the daytime running light
settings for 2007-13 vehicles (if the vehicle is equipped with this feature). The running
lights are activated while the engine is running, and the transmission is in “drive”.
VEHICLE FUNCTIONS EXPLAINED
There are six available running light settings:
•High Beams •European
•Turn Signals •Fog Lights
•Low Beams •Turn Lights OFF
My truck doesn't have daytime running lights, so I don't know if this would apply to my truck. For anyone that has an 06-08 1500, does the powerpaq allow this?
Old Nov 13, 2016 | 10:55 AM
HemiLonestar's Avatar
HemiLonestar
Doesn't work that way. However, if you know someone with a dealer computer, the setting can be changed to an export model that will keep the fogs on with high beams (did this to my Charger).
