02 ram 4.7 sounds like jet when reved
Old Dec 6, 2016 | 07:11 PM
Spencer Rawlins's Avatar
Spencer Rawlins
Unhappy 02 ram 4.7 sounds like jet when reved
Hello, I have an 02 ram 1500 4.7.
I recently drove through quite a bit of water. It ran fine for a day then I went to get on the highway and it sounded like it would blow up if I gave more than %50 throttle. Getting up to 60mph now takes a while. It runs fine till it hits 3k rpm. And it sounds like a 20 year old truck. Engine seems to be fine trans works mostly fine.
When the rims come back down it idles up and down hard for a while (which makes sitting at lights on the breaks interesting).
I can't find any vacuum leaks. Only thing I could find is the fan is loose. As in the shafts wiggles just barely with force and the fan moves separate from the shaft.
Sounds like a bearing is out around the fan pull your.
I am not a mechanic and don't pretend to be. Any help/guidance is much appreciated.
OfisiiiR
Old Dec 7, 2016 | 11:03 AM
superdak05's Avatar
superdak05
see if your fan spins freely or has some resistance, if freely the clutch is shot.
Old Dec 7, 2016 | 05:22 PM
Spencer Rawlins
With belt could be moved a little. Without the belt spins freely. Would bad clutch have affected water pump at all?
Old Dec 7, 2016 | 05:55 PM
Spencer Rawlins
Nevermind. Got home and checked it again. Fan clutch is seized up. Ahaha
