2008 Dodge Ram need to know if this block will work
Old Dec 26, 2016 | 10:10 AM
jws123's Avatar
jws123
Default 2008 Dodge Ram need to know if this block will work
I have a 2008 dodge ram 1500 4.7 my block cracked due to the person i got it from over heated it bad so the block is shot. What i need to know is i have a 4.7 block from a 2003 dodge ram/dakota i know heads pistons ect all that is different but is the bare block its self the same?
Old Dec 26, 2016 | 10:12 AM
jws123's Avatar
jws123
661AF, 033A is the block number from the 03 block and 661AF, 033AA is the number from my 08 whatts the diffrence??
Old Dec 26, 2016 | 11:10 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Search here. It's a great resource. http://www.car-part.com/
Old Dec 26, 2016 | 01:43 PM
jws123's Avatar
jws123
I know about that sight doesn't tell me anything related to the block i think the block number is different because of the pistons are shaped different but the same size trying to see if the bare blocks are the same..
Old Dec 26, 2016 | 06:04 PM
TNtech's Avatar
TNtech
The risk of an older 4.7 is going to be the way the crank and cam read the pickups. NGC and Non-NGC existed that year range 2002-2004 before they ALL went to NGC. As I recall there were some updates concerning the way the cylinder walls were lubricated and there was a timing chain and gear improvement.
If you got it hot, the heads are likely done for as well. They don't stand up very well on a 4.7.
The Mopar part numbers for SHORT BLOCK are different from 2003 to 2008. So is the price. But that's complete with internals.
The part number for 2003 to 2007 is same, but 2008 to 2011 is the same. This is consistent with what I'm seeing on the used search. 2008-2012 are showing up when you search the 2008 Ram. I would say stay 2008 and newer.
Old Dec 26, 2016 | 07:24 PM
jws123's Avatar
jws123
I sent the heads out to get shaved they where not in to bad of shape what happened was one of the cylinder walls cracked i will probably just get it re sleeved/rebuilt or if i can find a cheap used engine.
Old Dec 27, 2016 | 12:26 PM
TNtech's Avatar
TNtech
What would be "cheap" in your mind? Getting a later model salvaged would negate the machine work and gasket money spent.
Old Dec 27, 2016 | 04:20 PM
jws123's Avatar
jws123
Decided to get a used engine got a deal on one with 48k on it $2000 cheapest near me.....6 month warrenty every one else wanted way more lol
Old Dec 29, 2016 | 10:05 AM
TNtech's Avatar
TNtech
That's about as good as you're gonna do. Not bad.
