Wiper problems
Old Dec 29, 2016 | 06:23 PM
Legend1452's Avatar
Legend1452
Default Wiper problems
I have a 2006 dodge ram 1500 with wiper problems, the intermittent on the lowest setting sometimes swipes up to 6 times and also at all the other intermittent settings and then on the regular speeds when you turn them off they stop where ever they are when the switch goes off. My question also: is the intermittent switch built into the motor or is there a separate control module for the wipers?
Last edited by Legend1452; Dec 29, 2016 at 06:27 PM. Reason: additional question same subject
Old Dec 29, 2016 | 08:46 PM
Gone Fishin's Avatar
Gone Fishin
YUP,
The contact point in the wiper motor need to be cleaned. Common problem
Old Dec 29, 2016 | 09:00 PM
Eagle1452's Avatar
Eagle1452
Thanks I didn't know if there was a separate module that controlled them.
Old Dec 29, 2016 | 09:08 PM
Chet Ubetcha's Avatar
Chet Ubetcha
3rd Gen Ram Moderator
^^ This.
I honestly can't remember when my wipers didn't have a mind of their own. Some have indicated this as a temporary fix and have needed to replace the motor, but up to you if you want to try the cheap fix first, or just squash the problem for certain the first time out.
Old Jan 3, 2017 | 05:37 PM
Eagle1452's Avatar
Eagle1452
Cleaned the contact points on the wiper motor today, working like new.
Old Jan 6, 2017 | 11:39 PM
Chet Ubetcha
Glad to hear. Easy as you were led to believe?
