Need Help
Old Jan 15, 2017 | 02:15 PM
KS_Ram_Owner's Avatar
KS_Ram_Owner
Default Need Help
Hey guys! Been having a problem with my truck. It is a 2007 Ram 4x4 with a 5.7L. It has been jerking/jolting going down the road, RPM's jump up and down to the point of stalling. Sometimes it is hard to get started again and sometimes it fires right back up. It does throw codes. So far, I have changed the crank position sensor (3 times), air intake temp sensor, cam shaft position sensor, spark plugs, and the EGR valve. Since I have changed the EGR valve, it hasn't done it, but that was only this morning. Every time it has thrown a code, I would change the part that the code reader said, then it would throw a different code. Have any of you had this problem? If so, what fixed it?
Old Jan 15, 2017 | 02:30 PM
Ramx2's Avatar
Ramx2
mine did the same i changed the TPS sensor it hasn't had a problem now in 8 months
Old Jan 15, 2017 | 02:32 PM
KS_Ram_Owner
What is the TPS sensor? Not good with acronyms.
Old Jan 15, 2017 | 02:33 PM
66three83's Avatar
66three83
Throttle Position Sensor
Old Jan 15, 2017 | 02:56 PM
KS_Ram_Owner
Would the computer throw a code for that?
Old Jan 16, 2017 | 08:32 AM
MikeHTally's Avatar
MikeHTally
Oh, yeah.
