1500 to 2500 conversion
Old Jan 15, 2017 | 06:53 PM
bill91194's Avatar
bill91194
Default 1500 to 2500 conversion
I am currently researching for information about putting the rear suspension from a 2500 Ram into a 1500 Ram
And will also look at Front suspension conversion
I currently own a 2004 ram 1500 SB regular cab with 5.7l hemi and would like to get 2500 payload and towing
Old Jan 15, 2017 | 07:54 PM
p38251's Avatar
p38251
Buy a 2500. More to a 3/4 truck other then suspension.
Old Jan 16, 2017 | 01:44 AM
KasperR34's Avatar
KasperR34
1500 leaf springs are 2.5" wide, 2500s are 3" wide. You would need new hangers first off. You can however swap in the rear axle no problem.
Here are better options:
Get an add a leaf kit.
Add a top mounted helper spring like a 3500
Install rear air bags
Get coil over rear shocks.
As for the front end, if your truck is 2wd you have coils, you can upgrade to 2500 2wd coils as well. If you have a 4x4, you have torsion bars. Our T bars are discontinued and nearly impossible to find new ones, and we have zero aftermarket support. Either track down new ones, or have yours retreated to return them to near factory condition.
You can also get stiff front shocks and crank your T bars to add some height/stiffness up there.
If you want a 2500, buy a 2500. I have been considering an SFA swap but I honestly don't think it's worth it. It would be easier to keep the IFS and convert to the coilovers from an 06+
Old Jan 16, 2017 | 07:17 AM
bill91194's Avatar
bill91194
Thank you I do have a 2wd
using the add a spring is that based o my 1/2 ton springs @ 2.5 " 4(4/1)
I did locate a 5(4/1) kit
is the 2500 axle its self much stronger than the 1500
Old Jan 16, 2017 | 08:28 AM
MikeHTally's Avatar
MikeHTally
Probably, but the frame is still a 1500. If you need a 2500, trade the 1500. You won't be changing any capacities, towing or anything else. It'll still be a 1500.
Old Jan 16, 2017 | 09:00 PM
KasperR34's Avatar
KasperR34
Yes the 11.5" rear end is definitely stronger than our 9.25", I will swap mine as well.
No matter what, it'll still be a 1500 frame, however, we have very strong frames and adding springs will absolutely increase the capacities and such, but it will not make it a 2500.
