Transmission and transfer case trouble
Old Jan 25, 2017 | 05:37 AM
Dacota Bigler's Avatar
Dacota Bigler
Default Transmission and transfer case trouble
Ok dodge family i have a dilema. First off let me start out with i have a 2006 dodge ram 2500 TRX4 5.7 V8 Hemi. My transfer case recently had gone out in the truck, no big deal. Well last weekend i finally got around to replaceing it with a new trasnfer case. With no issues i got the old transfer case dropped and the new one put it. Now hear comes the kicker. After everything was all bolted back up and sensors and hoses were hooked back up i figured it was time to test it. So i started the truck up put it in neutral and made sure the transfer case was in gear, which it was. When i shifted into drive the engine loaded like it was in gear. But when i hit the gas the truck didnt move. So i tried reverse and the same out come the engine loaded but the truck stayed stationary. So i figuer id take it a step further i put the truck in 4 low and 4 high and tried to see if it would move then. But still the same outcome the engine loaded but the truck wouldnt move. I have no clue what could be going on with it now. So please any suggestions at all. Please need the help before i go dropping money on parts and such that i might not even need to replace. Was told it may need a transmission flush cause the filter could be clogged or the nore price option that the bad teansfer case sbapoed the tail shaft of the transmission what do you all think???
Old Jan 25, 2017 | 10:45 PM
p38251's Avatar
p38251
Why was the transfer case replaced?
Old Jan 26, 2017 | 05:22 AM
Dacota Bigler
Finally went. Was kinda hard on the truck between pulling heavy hauls and mudding in it when i first bought it 2 years ago and now it just finally went out
