Lighting help
Old Feb 3, 2017 | 04:16 AM
TracyK's Avatar
TracyK
Default Lighting help
Trying to get the running lights for our horse trailer to work......Have not worked since the connection from trailer to truck was damaged and replaced. The signal and brake lights work, but no running lights as required for night . Is this most likely a problem with a wire , ground , or is there a fuse that would be specific to running lights for trailer in the fuse panel in my 95 Dodge V10 that may be blown ?
I know it will require testing if not a fuse , but our fuse diagram is no longer legible and am hoping you can help me locate the fuse/s to check
Thanks
