2008 4x4 Ram Hemi motor removal
Old Feb 16, 2017 | 11:17 AM
Teddyc's Avatar
Teddyc
Default 2008 4x4 Ram Hemi motor removal
Motor is separated from trans but oil pan is hitting pumpkin. If I raise the motor to clear the pumpkin then the angle of the motor to the transmission is so great as to cause it to appear wedged and won't let the motor and trans to completely separate. I can't move the motor forward because of the pan and pumpkin. Does the trans need to be disconnected from the bracket and raised to cut down on the angle between the motor and trans. so the motor can slide out the last couple inches.
What are my options?
