Keyless entry
Old Feb 24, 2017 | 08:03 AM
ramdawg01's Avatar
ramdawg01
Default Keyless entry
Any easy way to tell if my 1998 Laramie is equipped with keyless remote?
I purchased it on a lien sale (yes, I know) and there appears to be some type of
alarm or other system at play.....when you turn the door key to off, the turn signal light
flashes once, much like the newer trucks/cars whose horn beeps to let the driver know
the alarm has been set.
Old Feb 24, 2017 | 08:12 AM
Go to this website and request a build sheet. That will tell you.
http://www.dodge.com/webselfservice/...ull&category=U
First you fill out all the required information.
Then in the area that says "Briefly describe" put "Vehicle Build Sheet" .
If you want to elaborate a little more as to why you want your build sheet, use the additional information area.
Usually takes a day or so to hear back from them.
Old Feb 24, 2017 | 08:31 AM
ramdawg01's Avatar
ramdawg01
Default re: Keyless entry
Thanks jkeaton!
Will definitely do that right away.
I owe you your beverage of choice.
