Emergency Break light with ABS Light ON
Old Mar 12, 2017 | 04:33 PM
pslake1's Avatar
pslake1
Default Emergency Break light with ABS Light ON
I have a 2005 RAM 5.9. I started my truck up and the emergency break light and the ABS light were both on and stayed on. The emergency brake was off and the ABS was fine. A few days later I was doing something else and notices a wire dangling under the truck. The wire went to the front wheel but initially I could not find where it went. After looking around a second time I found 2 green wires, I think one is a green wire with a white stripe, with no connector coming from the engine bay. I was looking from the top of the tire. They look like they were cut but have not been able to look again. I was also really in a area without many people, on our 34 acre property. Can anyone assist me with knowing how to get the connector and what to ask for?
Old Mar 12, 2017 | 06:30 PM
p38251's Avatar
p38251
Not sure if you can buy just the connectors. You may have to replace the hub assembly. The abs sensor is part of the hub.
Old Mar 12, 2017 | 08:24 PM
pslake1's Avatar
pslake1
The problem is the missing connector is not in the side going to the wheel.
Old Mar 12, 2017 | 08:28 PM
p38251's Avatar
p38251
Okay got ya. Maybe able to right that at rock auto.
