Oil pressure gauge keeps dropping to 0
Old Apr 10, 2017 | 02:44 PM
anthonyflhx's Avatar
anthonyflhx
Default Oil pressure gauge keeps dropping to 0
2003 dodge ram 1500 4.7l v8.
Just changed engine and trans oil. All of a sudden my oil pressure gauge started dropping to 0 and check gauge light comes on
I don't hear any engine noise. Just got this 2 days ago and nothing but problems.
How do I make sure oil is circulating thru engine and that's its not just a bad gauge or connection?
Old Apr 10, 2017 | 03:35 PM
Hook up a mechanical gauge to verify oil pressure.
Old Apr 12, 2017 | 12:46 AM
XiVLuisiferXiV's Avatar
XiVLuisiferXiV
does the oil pressure drop to 0 when you start to come to a stop or is it a random occurance.
if it does only drop when you are coming to a stop. does it go back up after pressing on the gas
Old Apr 12, 2017 | 06:45 AM
anthonyflhx
The gauge drops to 0 and stays there, then check gauges light comes on and cel. I dont hear any noise from engine though. I had to drive it home that way. If I pull over and shut off truck then start after a few moments the gauge may start working again. Its pretty sporadic. Seems to happen when engine gets hot or the longer Ive driven it.
EDIT***************
Just drove the kid to school which is a total of 6 miles round trip. As soon as I pulled into the parking lot the oil pressure dropped to 0 and the check gauges lights up. No engine noise though as truck sat and idled and went through parking lot. At a stop light I shut truck off a minute and started when light changed and oil pressure is back up to middle of gauge.
Drive another mile and the oil pressure goes out again. Now the CEL comes on and Im pretty sure its the same misfire on #8 cylinder.
Now one thing I notice and not sure if it could be related is the exhaust gasses stink. This exhaust has the catalytic converter on it and the idle and acceleration is rough. Im wondering if the converter is clogged and backing up fumes to the engine causing some of these issues? I know, wishful thinking right. ;-(
In any event Im going to have that exhaust changed to a single pipe and see if that helps any. Any ideas or feedback with this latest info?
Old Jan 15, 2025 | 10:07 PM
Shadedweller's Avatar
Shadedweller
Default Did you ever find out what the problem was with your oil pressure?
EDIT***************
Old Jan 15, 2025 | 10:53 PM
dodgetruck2's Avatar
dodgetruck2
7 year old thread, user hasn't been active since his post. Unlikely to hear back, from what I read I'm guessing most likely it was the oil pressure sensor. From personal experience 4.7s seem bad for them going out, not sure why, I don't think I ever had a bad one before owning 4.7s
Old Jan 17, 2025 | 01:15 PM
FabricGATOR's Avatar
FabricGATOR
What is your year make model?
Sensor, at least the analog type create variable resistance that it then displayed on the gauge.
Find your temp sensor and disconnect it (unplug) does the gauge go full hot or full cold?
So an open wire (broken, cut, disconnected) will show that (either hot or cold)
Then if you have the opposite anomaly then likely the wire is worn through and touching metal or pinched and grounding intermittent sometimes...
Please come back and tell (teach us) what you found and how you fixed it...
*you know from your experience here that it is a 'nothing burger' if you don't come back for 'Show N Tell'
patiently awaiting (either your solution or questions)
Cheers
