2007 Dodge Ram Rear Differential
Old Apr 13, 2017 | 11:05 AM
GreyDodge2007's Avatar
GreyDodge2007
Default 2007 Dodge Ram Rear Differential
I took my truck down to a mechanic to have a look over yesterday. I noticed a bit of fluid on the drive and its coming from the Tie Rod. However, when it was there they said that the Rear Differential will need to be replaced. I thought this was slightly odd as it doesn't make noise, its not leaking and the truck corners fine. Is there anyway that a mechanic can tell whats going on in the rear end without taking the cover off?
Old Apr 13, 2017 | 11:06 AM
Did you ask him why he thinks it needs to be replaced? That would be a good place to start.....
Old Apr 13, 2017 | 11:10 AM
GreyDodge2007
I did, he said it was loose and about to fall apart. To be fair I was a bit shell shocked as I took it in for a tie rod and wheel alignment and got a quote for $5K on repairs that need to be fixed.
Old Apr 13, 2017 | 01:38 PM
p38251's Avatar
p38251
Go some place else. It's loose is not a diagnosis.
Old Apr 13, 2017 | 01:43 PM
Agree. Sounds like you are about to get ripped off.
Old Apr 13, 2017 | 07:17 PM
MikeHTally's Avatar
MikeHTally
"Loose and about to fall apart" sounds like a diagnosis from Aamco (or Jiffy Lube).
