Hemi multiple misfire, no idle with codes
Long time reader, first time poster. I just bought my first Dodge. It's a 04 Dodge Ram 1500 Quad Cab 2wd Big Horn Edition. I got it for 1400 bucks so as you can imagine it does have some problems. I thought I'd try a forum instead of throwing parts at it. I always use forums to solve customer problems but this is a first for my personal vehicles. Anywho, it's throwing a code for multiple misfire. Barely idles if at all with codes thrown. Clear them out and it idles very rough. Driving it home it stalled at every stop without the throttle slightly pressed. During driving though it never died, just ran rough. It has zero exhaust on it from the man back, so with that it has zero o2 sensors I'm assuming. Not even sure how many it had? I know it's going to be a struggle but I appreciate any info you can give me on the truck and the problem!
what motor is in the truck? 4.7 or 5.7 or 3.7? i would start checking simple things like plugs and electrical connections. depending on how the plugs look i would do a compression check and check for intake leaks. pull the valve covers is also a good place to start checking for problems
sounds like you have a dead cylinder or a few
also how many miles?
