2006 Ram 1500 check engine light.
Old Sep 17, 2017 | 12:21 PM
David Valdez's Avatar
David Valdez
Default 2006 Ram 1500 check engine light.
I'm new so please forgive me if this isnt the right place to post this.
I have a 2006 Ram 1500 SLT 4.7 MAGNUM. A year ago the check engine light came on and this is what I've done so far. O2 sensors up and down, fuel pump and seals, cam sensor, crank sensor, idler pulley, hooked up the fog machine to see if there is a leak, and I just replaced the TPS and the damn light keeps coming on. I've had it at three different Dodge houses and even had a tech take my truck home and keep it hooked up to the computer to see why its acting up for three days. NO CODES AT ALL.
It will studded when I first start it for a bit. No throttle control at all. After a few seconds it revs up a bit and then its fine. Please help if ya can. I'm not a mechanic and I'm going broke fixing all these things with no remedy. Thank you in advance.
