how do I deprogram the key fob?
Old Oct 3, 2017 | 05:18 PM
cdndodgeman's Avatar
cdndodgeman
Question how do I deprogram the key fob?
I just got my 2008 Dodge 1500 QCLB and want to cancel the horn beep when locking the doors. The manual says hold the lock button for 6 seconds ,then push the panic button and release together. I can't get it to work. Am I doing it wrong or what?
Thanks
Old Oct 5, 2017 | 02:44 PM
HemiLonestar's Avatar
HemiLonestar
Thanks
If that isn't doing it then your only other option is a dealer or someone with dealer software, unless you have the upgraded EVIC in your overhead console. The higher end module has that option.
Old Oct 5, 2017 | 08:01 PM
cdndodgeman
Thumbs up Thanks
Ok thanks for the answer. I don't have an overhead console so I guess I'll go talk to the dealer.
Old Oct 6, 2017 | 10:10 AM
HemiLonestar
If you were local I could do it for you, but you're a tad far...should only cost you an hour's labor charge (always 1 hour minimum even if it only takes 10min). If they try to charge you more than that, find another dealer (or a shop that has dealer type software).
