No Brakes
Old Oct 20, 2017 | 06:15 PM
DebIM's Avatar
DebIM
Default No Brakes
Dodge 2500 2004.5 5.9 4x4, New pads on front, replaced brake booster, replaced master cylinder, bled lines, no brakes pedal goes to floor, have good steering so steering pump works. Prior shifter sticking in park, pushed on brakes, heard pop and that's when the pedal went to the floor, did the above replacements since this happened. Any suggestions would be appreciated.
Old Oct 20, 2017 | 06:44 PM
TrueDogman's Avatar
TrueDogman
Either you still have air in the system...you have a fluid leak or there is a malfunction with your new booster or master cylinder.
Old Oct 21, 2017 | 05:49 AM
bdhuntr's Avatar
bdhuntr
Did you bench bleed the master cylinder before you installed it? If not, you still have air in the system.
Air or leaks = low or spongy brake pedal
Vacuum leak or bad booster = hard pedal
Old Oct 21, 2017 | 03:17 PM
tomdel45's Avatar
tomdel45
i have a 1997 dodge ram 1500 4x4 pick up. on the front brake line that goes from the right to the left, i see on end goes to the break but can not find where the other side goes to
