‘05 4.7 accessory noise is killing me!
Old Oct 21, 2017 | 05:42 PM
bdhuntr's Avatar
bdhuntr
Default ‘05 4.7 accessory noise is killing me!
Changed tensioner & idler pulley- no help
Changed alternator- no help
Replaced compressor clutch bearing- no help
So as the noise disappears when the serpentine belt is removed, all that’s left is the water pump and power steering pump.
Take a listen and tell me what you think. This was prior to changing the bearing but the noise is the same.
Old Oct 22, 2017 | 11:17 AM
superdak05's Avatar
superdak05
remove the entire clutch fan system and see if the noise is still there, the clutch itself could be bad and the noise you hear is the fan blades
Old Oct 23, 2017 | 04:56 PM
bdhuntr's Avatar
bdhuntr
You, sir, were spot on! The clutch appeared to be fine, but it is definitely the cause of the noise. Kudos!
Old Oct 23, 2017 | 06:03 PM
TrueDogman's Avatar
TrueDogman
Thanks for posting your fix! Helps all of us !
