Radiator question
Old Nov 15, 2017 | 05:14 AM
bdhuntr's Avatar
bdhuntr
Default Radiator question
Went hunting yesterday morning, then got emissions tested and made a liquor store run. Got home and popped the hood for a general look-see. For some unknown reason, I put my hand on the radiator adjacent to the fill cap side and the fins were cold. As I progressed to the opposite side it got progressively warmer until I reached the other side, where it was hot (not too hot to touch, though).
Temps are normal. I would think this is indicative of a clogged radiator, but the radiator was replaced about 2010/2011 due to an accident so it is not original.
What do you think?
Old Nov 15, 2017 | 07:32 AM
are you having overheating issues?
Old Nov 15, 2017 | 11:55 AM
bdhuntr's Avatar
bdhuntr
Absolutely not. Needle is just below normal.
Old Dec 9, 2017 | 06:33 AM
bdhuntr's Avatar
bdhuntr
Default It was the cap
Noticed the same issue yesterday, after servicing the coolant level slightly the day before. The side opposite the cap was hot, and as I neared the cap side it was cool to cold. I did not turn the cap but when I pushed down on it slightly, it vented coolant. It must have been venting coolant ever so slightly (no visible leaks).
Bought and installed a new cap and fully topped off radiator and tank. Ran a load of wood and the entire radiator was warm and expansion tank was full.
Cheap fix! And something pressure testing the radiator would not discover.
