4 low engaging on its own!!!
Old Jan 8, 2018 | 10:27 PM
Chris Stites's Avatar
Chris Stites
Exclamation 4 low engaging on its own!!!
I have an 07 ram 1500. The truck has sat due to being broke down. I got it fixed and i drove it and noticed the 4 low light blinking and i could feel it trying to engage while driving down the road. I pulled over and messed with the gear selector and it went away. I started driving again and the light came back on. This time with the service 4x4 light. This time it engaged 4 low while driving luckily it didnt ruin the t-case. What could be causing this and what would be the solution.
Old Jan 9, 2018 | 01:53 PM
66three83's Avatar
66three83
Transfer case actuator. Mine did the exact same thing. It would change gears with the key out of the ignition!! Regularly would shift into 4Hi while rolling. Do yourself a favor, and unplug it right now before it does some real damage. I bought mine used for 80 bucks because I had heard that they rarely go bad. New will be a couple hundred. 15 minute job. You will see it sticking out of the side of the T-case.
