2005 ram 3500 p0500 help!!
Old Jan 15, 2018 | 09:59 PM
Jesse Dubreuil's Avatar
Jesse Dubreuil
Default 2005 ram 3500 p0500 help!!
Hey guys new to this site and seeking some help.
i have a 2005 3500 diesel Laramie 4x4 automatic.
i have the CEL on, abs light and parking brake light on. I have
A blue point scanner and I'm only getting p0500 code- speed sensor circuit, I started checking all fuses with a test light... all were good. Then gambled with a 50$ rear speed sensor at the diff, no fix, I then checked the continuity from the sensor plug to what I believe is the abs module (on top of the master cylinder?) both wires check good. I am now at a loss and it sure where to go next. Any help would be greatly appreciated l!!i ps also found 6 green wires under the driver side inner fender and fixed them with no fix!
