How much weight does 4-wheel drive add?
As the Subject line asks, how much weight does the 4-wheel drive system add to otherwise identical trucks?
I couldn't find it here with "search" and google wasn't immediately helpful.
Figured someone here would know right off.
Thanks in advance.
Thanks in advance.
According to autobytel.com the difference is 253 lbs. The 2006 1500 SLT with standard options weighs in at 4967 lbs. Adding 4-wheel drive it tips the scales at 5220 lbs. I found this to be a bit of a surprise, I guess I figured it took more drivetrain equipment or else the stuff they are using is very light.
I have a 4x4 QC 1500 with the 5.7. I have 92# aftermarket wheels and a turbo (no muffler). I weighed in at 5960# with me in it (180#) and 1/4 tank of gas.
On the dodge website, under specifications and weights, it shows a 450# difference between 2wd and 4wd
These aluminum transfer cases weigh very little. You can climb underneath one of them unbolt it and just lower it down very easy. Drive shafts don't weigh to much. I would bet all of the exta weight would be in the differential and shafts.
Thanks for the info.
I find 250# hard to believe. I'd think Dodge ought to know and their figure makes more sense to me, but if their web-builders function like some of their other personnel, all bets are off.
At least I now know a range to rag my buddy with regarding his 4X when we are talking.
I appreciate all taking the time to reply.
