Brake light issue.
Old Mar 2, 2018 | 07:10 PM
Seventime17's Avatar
Seventime17
Default Brake light issue.
So I just bought a 2002 dodge 1500, the last owner had no answer so here I am. My problem is when the accessory is turned on brakes work fine. Start the engine and the brake lights stay on and do not function properly. There is also a spliced wire near the steering column under the dash near the parking brake.anyone have any thp8ghts or suggestions?
Old Mar 2, 2018 | 07:25 PM
Disconnect the splice and see what happens.
Old Mar 3, 2018 | 08:36 AM
jrsick's Avatar
jrsick
Does truck have aftermarket stereo? I feel certain that that wire is supposed to be connected to the parking brake vice brake. Go ahead a disconnect it, and be sure to tape up the tap point. When disconnected, you will not be able to watch movies or videos on your media screen (but you probably can't now anyway because it is connected to wrong wire). Let us know what happens.
Old Mar 3, 2018 | 08:42 AM
jrsick's Avatar
jrsick
As I look at your picture more, there is some unusual stereo wiring going on. Previous owner may have also wired accessory wire to constant 12v source. The red and yellow should not be running through firewall, probably to the battery or a distribution block. Can you take a picture of your stereo and the wiring connected to your battery?
