Run 0 Gauge through quad cab
2005 Dodge Ram 2500 quad cab, I have a Fox Acoustics dual 12" box installed housing two Alpine Type R 12D4's each powered by its own Kenwood KAC 9106D. Anyone have any experience running 0 gauge wire through one of these pick ups? Deciding whether to go underneath the cab and have to drill a hole, which I'd really want to avoid, or if I can run it along the transmission tunnel under the carpet. Obviously would not want any noticeable lumps in the carpet, I could see this working except I don't know how to route it around the the rear storage area that the box sits in. Or should I try running two length or 4 gauge and if so how should I go about hooking that up to the battery and fusing it? Thanks for any input!
Sounds like a fun project.
Several ways you can go.
One way is to run it inside of the vehicle frame on the driver's side. It will come out just under the engine bay. Be sure to cover all the outside wire with the split loom tubing cover. I ran my back-up camera inside the frame rail and it worked great. I used some fish wire from Harbor Freight.
Another way is to run it under door sills and out of the carpet at the driver's feet. Look just above and left of where the hood latch cable runs and you will see a round hole with a black plastic cover. You can drill right through the plastic and go to the battery.
If you want to do the two 4 gauge idea, just run them to a distribution block. Two 4awg in, one 0awg out and to battery.
Excellent ground points: metal frame on front center console (lots of screws already there also), and the metal frames under both front seats.
I actually do have "half" of this system installed already. One type r and one Kenwood amp installed with 4 gauge ran through the clutch plate in the firewall and ran through the driver door sills. 4 gauge was a tight squeeze through that space even. So even the double 4 gauge idea would need to be ran under the carpet but would be easier to hide any lumps. Just wondering if its possible to run the 0 gauge under the carpet and out to the side at the back of the rear driver door to go behind the seats without any lumps. Id prefer under the carpet any way possible rather than under the cab to avoid drilling holes in the floor.
