LSD or not.
Old Dec 1, 2005 | 04:27 PM
abarmby's Avatar
abarmby
Default LSD or not.
Hi,
Anyone have a quick and easy way to find out if an LSD is fitted?
I don't have the glove box sticker with the info on it as in a previous post and the Carfax report don't have the LSD option even listed.
Help a newbie .............[sm=chattypair.gif]
Cheers.
Old Dec 1, 2005 | 05:31 PM
iengle's Avatar
iengle
Default RE: LSD or not.
Stick it in drive, stomp on it, and see if you get one tire mark or two. Better yet, take it to a parking lot, turn the wheel all the way to one side and try the same...
Israel
Old Dec 1, 2005 | 05:52 PM
osteodoc08's Avatar
osteodoc08
If you have a jack, jack up the rear (both sides suspended) and spin one wheel. If the other goes in the opposite direction, you have limited slip.
Old Dec 1, 2005 | 06:55 PM
HemiBuell's Avatar
HemiBuell
Osteo is right.
Old Dec 3, 2005 | 12:48 AM
ce2flaco's Avatar
ce2flaco
Or you can just look at the sticker on the rear axle tube out near the wheel. It will be there if you have it.
Old Dec 3, 2005 | 05:44 AM
Avanti's Avatar
Avanti
Or (since we seem to be collecting ways to check), jack up one wheel... preferably a rear , put it in neutral, and release the parking brake. Try to turn the wheel in the air. If it turns, no limited-slip.
Old Dec 3, 2005 | 08:32 AM
518Comanche's Avatar
518Comanche
Iengle's way would be alot more fun!!!!!
Old Dec 3, 2005 | 09:00 AM
TheHitman's Avatar
TheHitman
hate Lsd wish i had posi
Old Dec 3, 2005 | 11:04 AM
Batphreak's Avatar
Batphreak
ORIGINAL: TheHitman
Lsd=posi
Back in the day mopar called it SureGrip. Look at the guts once, all 3 work the same way, a clutch pack that locks the 2 halves of the differential together (yes that's over-simplified).
Old Dec 10, 2005 | 08:18 PM
ce2flaco's Avatar
ce2flaco
I just got a Detroit True trac installed Friday. After the break in period i'm going to see how much abuse it will take on some "tire dangling" trails. It should be a marked improvment over the factory LS.
The good news is that when my factory unit came out there were none of the fragments of metal like so many others have reported.
Anyone want to buy a "used" LS unit?
