Obd2 won’t communicate
Old Apr 3, 2018 | 07:48 PM
Dlayneb's Avatar
Dlayneb
Default Obd2 won’t communicate
So like I said I bought this truck from an auction with no key got one cut but at the dealer they couldn’t communicate with it so I could program the key. Would start for 1-2 sec then shut down. I tried to test the plug with a test light and the ground pins 4 and 5 wouldn’t light or the positive number 16
Old Apr 4, 2018 | 07:57 AM
gcburkett's Avatar
gcburkett
If you have no voltage at pin 16 maybe you have a bad fuse. The fuse for the DTC usually power other stuff but I don't know what it would be for your truck with looking at the wiring diagram for your model.
Old Apr 19, 2018 | 05:55 PM
karlmich's Avatar
karlmich
need year of truck. pin 16 usually come from IOD circuit it is the fuse that has a black pull up thingy on it.
