2009 dodge ram 2500 HEMI Driveline vibration i need help!!
Old Apr 7, 2018 | 12:30 PM
jws123's Avatar
jws123
Originally Posted by bdhuntr
Check your harmonic balancer. Just replaced the water pump and timing chain cover gasket and found the balancer was shot.
Its not engine related its driveline related if i shut the truck off or put it in N and coast while goin fast its still there.
Also i just checked motor mounts they look good no movement,.
Old Apr 8, 2018 | 08:23 AM
Gone Fishin's Avatar
Gone Fishin
check the pivot ball in the front shaft double cardigan joint. Having the shaft balance checked will certainly find/eliminate any problems related to the drivelines
Old Apr 8, 2018 | 09:24 AM
jws123's Avatar
jws123
I took front driveshaft out and drove it was still there but i am going to pull both and drop them off to get checked.
